stingray101
Thread starter- Joined
- Dec 19, 2009
- 3
Hi. I own a 2001 Caravelle 209 Bowrider. It has a Volvo Penta 5.0Gi engine. Last summer, the throttle control went out, i.e. "started spinning." Neutral essentially stopped working. I was able to use it in Reverse and Forward, but not neutral. We took the housing off and saw the gears were worn, so I am looking to get it replaced. I talked to a local dealer and they want a ton of money. Is this something someone without a ton of knowledge can replace? And, does anyone know if this control unit I found on Amazon will work?
https://www.amazon.com/Volvo-Penta-...WcqPhLlidpKpXnj7UpCSe9srvEssj9RoaAgCTEALw_wcB.
I found a SeaStar throttle control on Wal-Mart that says it fits most engines, and it's way cheaper. Will this one work?
I'm trying to avoid paying $1,000+ to a local boat repair shop, but not sure I can avoid it.
Thanks for any feedback. - Lee
SeaStar CHX8051P Xtreme Series Single Lever Side Mount Dual Function Control with Engine Cut Off Switch & Trim Switch - Walmart.com
Buy SeaStar CHX8051P Xtreme Series Single Lever Side Mount Dual Function Control with Engine Cut Off Switch & Trim Switch at Walmart.com
www.walmart.com
