throttle control
twologs5
on my pontoon boat after it set all winter in storage the throttle moves very very hard worse in reverse is there any way to lube it is a 90 hp mercury in a 2006 princecraft
you can pull the control and lube that up, however most likely teh cable(s) needs replacing
mtsaz
There are you tube videos showing how to clean/lube cables using compressed air. I am sure if yours is dirty and dry it migh work but if there is anything else wrong- you might have to replace it. Cables cost about 50$---so I am not going to spend a lot of time and energy trying to fix a 10 yr old (or however old) cable assy--
