Throttle lever stiff
Vere
Hi
Me again !
Having just chaged ignition key switch and solenoid on engine, Ive re-assembled the parts and now find that the throttle lever is extremely stiff going forwards. In neutral its fine, and in reverse its fine.
I did obviously move the throttle mounting about as thats where my ignition switch is, but I did not adjust or touch cables, and everything is back in spot it came from. I can?t see any obvious kinks etc in the cables...
Any ideas ?
tashasdaddy
Re: Throttle lever stiff
go back in and check, something is binding. make sure the shift teeth are correct.
