4300 is still low for that engine should be 4800 -5k at WOT.
If you go in shallow water lift the drive up would think you can swap props in the water , done it many times. or do you have an extended swim deck covering the drive ? Just gotta be careful the thrust washer doesnt stick to the prop and drop off in the water
