edfishing2
- Joined
- Mar 6, 2011
- 144
Guys,
I have all the parts in throttle cleaned and lightly triple guard greased. See attached diagram item numbers 76 and 82.
These seem loose side to side after installing the washer and lock nut. Is this last washer supposed to fit up over the shoulder? I would think this assembly would be kinda tight. It is easy to rotate and no play axially (up/down). It is just if you twist the arm it has play.
Thanks,
Ed
Thanks,
Ed
