duckhunter55
Thread starter- Joined
- Oct 13, 2007
- 94
Should the back butterfly valve on a 1978 25 hp johnsons carb be wide open when throttle handle is turned to full throttle? Im not talkin about the choke valve but i guess the throttle valve, behind it. Reason i ask is cause when i turn my throttle all the way open the throttle valve only opens a quarter or less. By pressing down on the throttle linkage ican get it to go wide open, but not with throttle handle. Also on throttle handle there is play during the turn which i guess is whats causing the looseness in the linkage. Also after starting motor foe first time then cutting it off, when you go back to start it will take at least 10-12 hard pulls, and then pulls get lighter and it starts. Nothing in powerhead has been messed with, and the motor was running fine back during summer.
