Throttle stuck in neutral
Charger_
MPC 4000 GEN II Series Mechanical Panel Control - Press button to rev engine while in neutral but pin falls down and cant disengage button (no longer works) to bring out of neutral. This does not happen every time. Is the issue with the spring or the button itself?
ahicks
I would assume the only way you're going to know is to take it apart, check it out, clean and lube, then see where that leaves you....
