The little button in the middle of the throttle lever, how does it work? I cant find it in my manual. Are you just supposed to press it and then start your motor and be able to throttle with out the prop spinning?
That doesn't really help me out. Do you need to hold the button while moving the throttle into forward posistion? What exactly does it do? I assume it disengauges something?? Thanks
Step 1: Push the button.
Step 2: Move (or pump) the throttle lever as desired and release the button.
Step 3: Leave the lever about 1/3 forward. (fast idle position)
Step 4: Start the engine.
Step 5: When engine is warmed up, return the lever to neutral. The button will pop back out and gearshift will now be re-engaged.
Step 6: Go forward or backward as desired.
