through hull exhaust
icwebpeople
i have a 302 ford, omc stringer. can i run my exhaust through the hull and cap off the holes in the bellhousing -intermidiat where they exhaust tubes go now?
Dhadley
Re: through hull exhaust
Yes, you can. I might suggest you check with the cops about which test they use to determine if your going to get a ticket or not. And what the penalty is. Better to find out now than later.
icwebpeople
so i can just cap the holes where it is going into the intermidiate?
whywhyzed
Banned
Do you have Selectrim? <br />If so, remember the trim tilts the whole engine in relation to the hull. Need to use flexible hose for the exh.
icwebpeople
do i have to do any thing for back preasure or can i go staight off the riser with exhaust hose to the through hull tips with internal flaps.noise isnt an issue
