73 Dolphin
- Joined
- Oct 8, 2008
- 308
I just finished doing a jet pump rebuild on my wifes 1995 Sea Doo gtx 657. It did have an aluminum pump originally which was in horrible shape. I didnt realise this until I pulled it to change the wear ring. So I bought a plastic pump and changed the bearings and wear ring.
It seems 95 was a year with both aluminum and plastic pumps. I decided on the plastic after seeing what salt water will do to the aluminum pump.
So I put on a new reverse cable today and tried to reinstall the pump.
The mounting tabs on the pump which attach it to the bolts through the hull are a lot thicker than the original aluminum pump.
As a result although the pump mates up I cannot get the washer and lock washer on.
So the question is if the through hull jet pump mounting bolts can be changed out for longer bolts.
Has anyone tried this ? Are they fiberglassed in ?
I would hate to have to get a aluminum pump to rebuild and put back on as I have an as new plastic pump ready to go on !
Thanks !
Thanks !
