We're getting our boat repowered after our old 5.0L Mercruiser with Bravo 2 drive died. The drive is fine so we are keeping it which means its just a new engine. The replacement engine the mechanics are putting in is the newer 5.0L MPI engine with the closed cooling (Its not the whole Seacore system). They are telling us that it will need to use both the sterndrive water pickup and an additional through-hull scoop fitting because of the closed cooling system. I found this odd as the previous engine had closed cooling (only through the engine - not manifolds) but did not require an additional pickup. Is what they are telling us correct?
Also when they showed me the pickup going in they said that the slots on it would face towards the stern. This seems strange too as I thought that would restrict the intake of water.
I'd appreciate any help you can give.
Cheers
Chris
Cheers
Chris
