OK guys:
My 2001 2700 SCR with 7.4 MPI motor has lost much of its power. I changed the fuel/water seperator filter, cleaned the air intake, and looked at the distributor cap/wires. Everything seems fine, but still not much power. Temp is fine, oil pressure is fine. Just doesn't have the power. I do not think the prop is slipping, since the engine can not build the RPMs. I may try to check the wires on the spark plugs, but I doubt one came off. It does feel like a piston may not be firing, but at idle it sounds and feels normal. That said, it also seems to have a bit of a rich smell, like there is excess fuel in the exhaust (maybe).
I do see the tach. occasionally drift high for no reason, then come back down - but there is a recent post that indicates that problem may be dirty tach leads...?
The marine shops around here are uber expensive, and my wife and I are considering a major relocation, I hate to get deep into the boat - especially now. That said, I have no trailer and I am pretty much stuck to things I can do at the dock.
Any last minute ideas before I throw in the towel and call the shop?
Thanks
Thanks
