thru hull tips above risers
beninlou
i have a mercruiser 350 that im in the process of doing thru hull exhaust on.my question is will it work with the tips above the risers?thanks for any help
Bt Doctur
Re: thru hull tips above risers
with dry exaust, not with water flowing thru them
Ayuh,... Wet Exhaust,..??
Water flows Downhill,....
beninlou
well i guess i need another plan because its wet exhaust.
legoman67
you can install a vernalift, that is what they use on large inboard boats where the engine is below the water line...
google vernalift and you will get results...
we are installing the through hull exhaust on our boat tonight aswell... :D
