Re: Thru hulls vs thru leg back pressure test
I'm not sure I buy that a mile an hour or so is really that reproducibly measurable. Think about it... you pick up more than that when going from flat water to a little light chop...
I was thinking the same thing about the small differences in top speed and 0-30 MPH times, Tim. On the other hand, I also found the HUGE differences in 30-50 MPH times (almost 50% difference????) to be really questionable. Never timed any boats 30-50 to see how repeatable it was, but I don't believe exhaust tips could repeatably make as big a difference as the test showed without making a HUGE difference (10-15 MPH maybe?) in top end also.
I've mentioned the drive heat thing a couple of ties and no one seems to say a word about it... I know that heat is a big enemy on overpowerd drives, and that people claim a big difference with drive showers, but why then don't we worry aobut running ALL of the exhaust gasses throughthe outdrive... Surely when runing flat out for a good bit that contributes as much heat as anything to the drive? (unless the water is cool enough that it drops the temp to below oil degredation temps... but wait, we let the water drain on the bottom part... I have a feeling that the heat capacity of the water as well as the heat of vaporization is the reason that it's not a problem
I'm assuming that the exhaust gases are substantially less than 212 degrees by the time they hit the outdrive (hopefully no steam in your exhaust). My guess is that the outdrive normally runs hotter than 212, since a common problem on Bravos without coolers is salt and calcium deposits baked onto the drives, caused when they come off cruise and drop back into the water hot, boiling the water away and leaving the salt and calcium.
Merc also recommends an exhaust tube as opposed to an exhaust bellows with a big block, that probably helps some also with the drive cooling issue.
Can't help any to have the hot exhaust running through them though, so I would expect the thru-hulls to help at least a little in that respect.
