Re: Thunderbolt 4 engineTiming
I have a re-power engine using a 1998 5.7 vortec engine with roller cam. ignition is with thunderbolt 4.
1.when setting the timing, do I just use the thunderbolt 4 instructions? the thunderbolt 4 came off a 1995 mag alpha.
also:
2.is there a rev limiter in thunderbolt 4 and what does it use as a max wot? is this adjustable?
3.is there somewhere I can read about the thunderbolt 4, how it works etc. and timing instructions?
4.if the engine is set to spec, runs good etc. is there any need to confirm advance to match specs, or that just for troubleshooting?
Always a good question... Quite a few people are making the move from one to the other, and asking the same question.
1. What determines what the initial advance should be, is it the engine characteristics or the ignition system? It's probably a combination of both of those, and the quality/octane of the fuel recommended by the manufacturer... Unfortunately that doesn't answer the question, and it gets harder. TB-IV was on the non-Vortec engines, and only on non-Vortec engines. When the Vortec V8s came out, the new engines were given the new TB-V ignition system. So we don't have either system being run on both engines.... No help there. The TB-IV on the non-Vortec engines was run at 8?BTDC. The new engines are specified to 10?BTDC with the TB-V.. We do however have one document from April 1994 stating the TB-V systems should be set to 10?BTDC. Given that Vortec V8s didn't appear in the Merc line-up until mid1996, one may assume that the 'new' system setting of 10? was also meant for the non-Vortec engine.... This would lead me to think that any engine running the TB-V would be set at 10?, and any engine running TB-IV should be at 8?.... (I think my logic is good :noidea
2. No rev limitier on TB-IV. There is on TB-V, and it is set, on production, at max recommended revs for that engine plus 50, not adjustable. There are 4 different TB-V modules for the SBC... One each for 5.0l Alpha, 5.0l Bravo, 5.7L Alpha and 5.7L Bravo. And there are also two different modules for the V6, one for Alpha, one for Bravo. There will also be a whole bunch of modules for the big blocks too. (haven't done enough research into those just yet... maybe tomorrow
3. Walt T pretty much nailed how HEI systems work. Inside the module is a high voltage transistor. It's just a very fast electronic switch that acts just as the points would have in the old system. When the timing circuitry requires a spark to be fired, the transistor turns off, collapsing the field inside the coil and generating the spark. For the setting of the timing with a TB-IV system, just do it like you'd do a points system. Idle the engine down to 650, point the timing light at the marks and rotate the distributor until the timing marks are where you want them.
4. Checking the advance curve is a diagnostic tool. I like to do it because it's very quick and simple (and doesn't cost anything), and rules that out as a possible cause of run quality issues. I guess it's a hang-over for the weights and springs era. Weights and springs could break or seize, causing problems... Don't think I've actually seen a TB-IV module (that's working) not advance.... The usual failure mode is ...working, then dead....
Just be aware that there are many different TB-IV modules. This is the list; V6-14, V8-24, V8-22, V8-22A, V8-24S and V8-20R.. Each has a different curve and maximum advance. Also, this advance is the module advance only. If you want to know what advance your engine is running at, add the initial advance to the advance on the curve. So if you have a V8-24 module and have the timing set at 10?BTDC, then at 3600rpm (and above) the advance measured on the engine timing marks should be 34?BTDC...
Service bulletin 95-11 has all the curves for all the system for all Mercruiser engines. There is also a 'generic' TB-V curve on the last page (read the caveat below the graph)....
I haven't seen a write-up on how the TB-IV system works, but it's very simple (and surprisingly good). For a description of what the TB-V system does there is a very good write-up in the newer manuals. I extracted it a little while ago for another member :facepalm: to read... Enjoy
http://forums.iboats.com/attachment.php?attachmentid=209033&d=1377157742
Hope that helps....
Chris.......
