amplay
Thread starter- Joined
- Sep 29, 2022
- 71
You guys are being so helpful !!
I fixed the jumper on the OP sensor, it was not done well. I then put a meter on the wires for the Fuel Pump, and had 12V continuously. Then I tried pumping the fuel into a bucket, and that worked without stopping. I then put all back together, and started the engine. It ran at 1500 RPM for ~ 30 seconds and just died (as usual). So I'm thinking a bad fuel pump, unless one of you has a different suggestion. I was unsuccessful loosening either the top or bottom bolt to the pump, as they are too tight. I sprayed WD40 and will try again tomorrow. Thanks .
