thunderbolt 800 wont go into gear...
inboardnewbie
I rebuilt the carbs , fuel pump, and impeller now it wont go into gear??? I can spin the prop in either direction wether its in reverse neutral or forward? Whats happened???
sutor623
Re: thunderbolt 800 wont go into gear...
Shift shaft splines weren't lined up properly when you put the lower unit back on. Yank er back down, put the controls in forward, and turn the shift shaft spline in the lower unit until the unit is I forward. Slip the unit back up and before you tighten it all the way down check your shifter. This is a common issue.
inboardnewbie
Need some serious help guys i can not for the life of me get my lower unit back on and in neutral, im about to die!!!
I can turn the shift shaft 300 degrees and it wont go in neutral however if i turn it as far as i can counterclockwise i can put vice grips and turn it a little further and my prop will spin freely either way, now when i install the lower unit back on it , the prop ratchets counter clockwise and when i start it it wont go into gear...
What's happening?
The controls are in neutral also.?
Moody Blue
shiftshaftcam.jpgDrop the lower unit once more (if you haven't got it fixed already) and get a feel for how the lower unit shifts. Don't use vise-grips on the splined shaft, a 3/8" (I think) socket fits nicely onto the splines, and you can rotate the shift shaft easily with a ratchet.
The shift cam attached to the shift shaft has 3 lobes that define the gear selection. The cam is free to rotate 360*, but the gear selection occurs only within about 45* of rotation. See attached photo for reference.
Once the cam is in the "free" zone of 300* as you described, it is outside of the shifting region. Continue to SLOWLY rotate the shift shaft CCW and you will feel a small detent. Stop. This is the FWD gear detent. The prop will lock in one direction and ratchet in the other. SLOWLY continue to rotate CCW until you feel the next (more distinct) detent. Stop. This is the NEUTRAL gear detent. The prop will spin freely in either direction. Continue to rotate CCW until you feel another small detent, and this will be the reverse detent. Stop. The prop will be locked in either direction. Do not rotate any further CCW. Now rotate the shift shaft CW back to the neutral detent. Do not rotate the shift cam CW (other than changing from N to FWD or R to N) as you may damage something due to the shape of the cam.
Put the control in neutral and disconnect the shift linkage from the motor. This will allow the upper and lower shift shafts to easily align, as you install the lower unit, if they are slightly out of alignment. Once the lower unit is in place, you can adjust the shift linkage as required at the motor.
sutor623
^ great walk through.
