89 thunderbolt iv on a 305
I've been chasing ignition gremlins in this thing all summer.
When the engine is running at idle what should the voltage read when leads are on the pos & neg terminals of the coil?
Right now at idle the positive term with the engine block as a ground reads 12-13v
When reading pos term voltage and using the negative terminal as a ground it reads 2.2-2.3v
Is this correct?
Thanx
Is this correct?
Thanx
