jsferra1
Thread starter- Joined
- Aug 10, 2007
- 31
I have two issue that I know of ( and hope only two ).
I have a 1997 5.7L Thunderbolt V Without the Knock Sensor,one issue is my Tach is NOT working I will start looking in to that this week/end the other Issue I have and it may be connected to the tach is Prior to setting the timing I put it in basic mode (ground the Pur/Wht wire next to the carb like the book said) set the RPM using my had tach, and set th etiming using an Adv timing light and mirror ( you can NOT see the mark with out the mirror ) and having to use the mirror and timing light at the same time while just about standing on your head is no fun. But I get it set the best I can any way. Then turn it off pull the jumper off the Pur/Wht wire and start it back up and there is no change in RPMs at all. So now I wonder if there is something else wrong or the RPM's should stay the same in which case why would I need to jump the wire if nothing changes.
I have changed the Spark plugs, Cap, wires, filter at the carb and the water/filter , bellows, trim sender, trim limit swt, U-Joints, Impeller, shift cable, cleaned the carb, Gimbal bearing and I still have not even taken it out for more then a quick test two times.
