I recently changed out my u joint bellow and noticed oil in the old bellow. I had my Mechanic change the seals in the upper housing. I installed the upper housing with the new u joint bellow. After the drive was put back together I hooked a hose up to the drive. While the engine was running and water going though the system I noticed a ticking/tapping sound near the upper housing of the Drive. I put the drive in gear and ran at 2000 rpms back down to idle and still the
sound was there. Oil level in drive is correct with 30 weight Chevron oil. I have a 280 drive as well. Any thoughts, I have not put a load on it yet.
