I have a 1997 Tigershark 770. After being in storage, I have a starting problem. Battery is charged and the starter is whirring but seems to not be engaging the flywheel.
Does it have a starter pinion gear like a car that extends when the starter spins and retracts after starting? If so, is the likely place to look? If not, where should I be looking?
Does the starter have to be removed to get to the pinion gear or can it be accessed through the flywheel cover? Should I try to spray a lubricant, wack it with a hammer, or some other intervention we used in the 70's?
Thanks for any help! It will be greatly appreciated!
Tim
Tim
