Tillotson Wb 10d ?
fordmustang
I HAVE LOOKED AND LOOKED FOR A FLOAT SETTING FOR THIS CARB MODEL NO LUCK YET. ALSO THERE IS 1 SCREW FOR MIXTURE DONT KNOW HOW TO SET IT, IF ANY ONE HAS ANY INFO PLEASE HELP, I TOOK IT OUT TODAY FOR THE 3RD TIME CAN'T SEEM TO GET IT RIGHT?:confused:
jerbear56
Re: Tillotson Wb 10d ?
To get the exact specs, it's best to know what motor the carb is on. As for the adjusting screw, I can give you the adjusting procedure if needed, but one and a half turns out has always worked really well for me.
FYI, be sure to gently seat the needle before backing it out as it doesn't take too much to pressure to damage it.
fordmustang
It's On A 1972 Chrysler 105 Model No 1057 He. Did Find A Rebuild Kit On This Web Site. Thanks A Bunch Jerbear
jerbear56
Here you go, these are the specs from the factory service manual.
Turn the carb upside down. The distance from the bottom of the carb to the bottom of the float on the side opposite the needle should be 13/32"
To set the float drop, a picture would be worth a thousand words here! Hold the carb with the float hanging down. The distance is measured at the inside edges of the float, and there should be 1/16" difference in height. Best checked by holding something level from the lowest edge and measuring from it to the other edge of the float.
Hope this helps, and good luck!
