snookhooked
Thread starter- Joined
- Aug 19, 2008
- 159
I started the day with a problem with my T/T. I went out there to raise the motor to trailer to the dock. it started going up at a slow place but acted like the batteries may have been going dead and it stopped. now I did a check on the batteries and they showed 12 volts. since my meter is a harbor freight mete, I took it as maybe its not correct, so I just bumped the motor over and it did just fine so since it was 4 am and I did want to wake my neighbors up, so I took it to the water and ran the boat around and checked the voltage and once again it was 12 volts. the relays are both clicking and everything I could test shows power at the right volts. since I did a manual pressure release and the motor is in the down position, I cant lift the motor back up. I cant pick it up to lock it so Im thinking either Im not getting power to the motor part on T/T or it just went bad? maybe someone has went through this and can tell me how to make sure whats the problem before I go buying things I may not need. the motor is a 1992 150hp Evinrude Spit Fire. its either has to be power or the motor. thats my opinion, please give me yours. Thanks for your time.
