Re: tilt and trim fluid
Thank you, SoLittle....<br />Tony, obviously you caught my mistake before I went back and edited it.<br />Chances are your sleeve thickness will not allow boring to the 3.685 size I think you are looking for.<br />As for the Trim and Tilt fluid, that IS what you should put back in it...that's what it's called, name right on the tube, at any marine dealer.<br />If you are looking for another answer as to whether you can replace the fluid with some other type such as tranny fluid or something like that, don't expect an answer other than what I gave you...there is NO replacement.
