Tilt and Trim motor
mobgod
Ok i'm so lost my motor was working fine i tried to move it today and nothing so i hit the motor with a little hammer and than the engine did move about 1 foot and stopped could this mean the motor went on me i also did test on the wires hooked stright up to a battery and engine did not move so i did a continuity test and my meter beeped i believe thats telling me something is grounded in the trim motor. Now i did make a call to see what motor i would need i have a 200txl77c johnson but the trim looks newer how can i find this info out also,reason why the one suggested is a 3 wire and the one that is on now is a 2 wire thanks all
etracer68
Ensign
Re: Tilt and Trim motor
Maybe hit it with a Bigger hammer, might move 3 foot.:D
etracer68
Ensign
Have you cleaned, all connections? Is the battery charged up good? I would take all wires off motor, and battery, and clean them real good and try again.
mobgod
Nothing to clean I cut the wires and tried direct but I'm getting nothing at all could the motor gone bad or a brush grounding out inside?
boobie
If you hit the mtr with a hammer and it moved, you have a stuck brush in it.
mobgod
OK anyway to fix this or do I need another motor? Never taken the motor off so not really sure what I can use to take the engine off to support it that would help also if you can suggest some thing for that the other problem I'm having is the book is telling me I need a 3wire motor but the one on there now is only two wires so I'm lost with that back to taken it off just need help on what I can use to get so the motor will hold do I build some thing do they make some thing for this ect.. ..
emdsapmgr
Your engine shipped from the factory with a 3-wire trim motor system. Some time in the early 80's OMC went to a 2-wire system. Someone has changed your trim system. Both work equally well. The 2-wire system required a small electrical box with dual relays instead of a single solenoid. In the long run, it's probably more reliable. Many of these boxes on the newer enines mount inside the cowl, bolted to the aft outer exhaust cover. Probably the easiest thing to test on this system is the pair of relays. It's not unusual for one of them to malfunction. The system will may function in the up, or down. You can swap the relays and see if you get any change of movement in the trim motor. From the sounds of your 2nd post, it sounds like you have already wired the motor direct to a battery. If you get no movement when connecting direct- you will probably have to replace the motor.
mobgod
OK thanks I do have two relays one is for up the other is for down so guess it was changed but the problem is what one do I order do I just get the one that looks like mine with the two wires?
BillP
I just took one (2 wire) off my 1991 70 omc last weekend. The trim motor was stuck and wouldn't move when hooked directly to the battery. I pulled engine off the boat, unbolted (4 bolts) the trim assy from the bracket, swung the bracket away and gained access to the previously hidden socket screw (there are 3 socket head screws on this version and it's probably what you have). Once the trim motor was pulled from the mount, I unscrewed the cover and checked the electric motor. Everything looked good but I pulled it out and cleaned it all. It went back together and now works fine. The only trick was having to tie the brushes back so they would let the winding part slide back in. I used string and wrapped it on the brush wires to hold them flush. When the winding is slid deep enough it holds the brushes back and you release the string. This will be easily understood if you take it apart.
I was going to buy a new trim motor at first but found cleaning was all it needed. It was stuck from sitting a couple yrs and the cover had a tiny hole on top that I thought rainwater entered and trashed the electricals. In reality a whack from a hammer may have broke it free but the cover was rusted and I thought it needed replacing anyway. In the end, I ground the paint off the cover and found plenty of metal left. Then plugged the tiny hole and coated the outside with 1:1 epoxy glue to seal it. Not a big deal except for having to pull the engine off the transom...which required disconnecting everything and a friend to help lift it off.
mobgod
OK thanks that's what I'm going to do pull it off and change the motor can you or anyone point me to something to pull the engine off to heavy to hold
Tim Frank
An engine hoist maybe? ;)
Or a chain block if you have an overhead support that is strong enough.
mobgod
I know that lol do they make something to hold the motor that I can hook it up to when I'm done pulling it off?
BillP
I built a stand out of 2x8 lumber for larger motors. My 115 & 140 Johnsons came off transoms using a cheap $20 come along and chain up to an oak tree limb. This last engine pull I slid the 70 (while on the transom) away from the steering cable to release it from the tube instead of pulling the cable back under the deck. The cable was threaded though small holes back to the steering quadrant and I couldn't get slack without taking the cable off that end too. Good luck.
bp
just a idea but could you just block the trailer and strap the lower to a tree then undo the bolts that connect the trim unit to the transom mounts then gently jack and swing the trim unit out far enoght to get to the motor?. mines smaller and newer and i was doing it that way being lazy and it would have worked perfect had i not snapped a bolt head. 3 beer job turned in to a 12 beer job and i then had to pull the complete motor to get the transom mount side plate off as the bolt snapped leaving 1/2" stud so it wouldnt swing
