Tilt and Trim motor
mobgod
ok i've read the book is there a easier way to take the motor off or do i need to disconnect the trust rod and so on to get to the motor ?
64osby
Re: Tilt and Trim motor
I won't be able to help with your question, but it might help if you provided a little more info. Motor size, model and year.
mobgod
It's a 200 TXL77C just wondering if I can do this without removeing the tube if I can just knock the pin out than take the six bolts off ect.. ..
Will Bark
I don't know if your unit is like mine on a 1987 150hp jonny but I was able to raise the motor up and using the tilt lock support the engine and then knock the tilt rod pin out. Then I removed the bolts holding the unit between the brackets and removed the unit. This was just to remove the pump motor; I had to cut the blue and green wires but I was replacing the motor anyway. Good luck
mobgod
ok when i knock the pin out will the motor go flying down,do i need to support it ect... also that is what i need to replace also the motor i got two of the screws out but the other is a mother because of the bracket so i would say this is the only way this can be done correct?
i tilted mine to the lock position then blocked the trailer wheels and tired the lower to a tree. (redneck safety) then knocked the pin out and undid the 6 bolts and pulled it out (i didnt cut the leads as they have a little tag inside that lets you get the white connector off but after lots of cursing if i did it again i might). i would surgest backing all 6 bolts for the tilt out at least 2 turns first as they can be a pain and if they break then the whole motor has to be removed. maybe with a socket set and insert tip you can get the last screw with out removing it
Will Bark
My motor has the tilt lock mechanism on it and I just used that. You could use a short 2x4 to block it up. My 3rd screw is too tight or close to get anything on it. 2nd what Glenn said be patient with those bolts; it took me a whole day to get just one out. I had to use a lot of oil and heat to get it with a hardened socket and breaker bar. That was before I got an impact wrench. Good luck.
mobgod
OK I guess what I need to know my engine might fall when I take that pin out so I need to strap my lower unit correct? For the bolts they are fine came right out I guess that's a good thing
mobgod
i tilted mine to the lock position then blocked the trailer wheels and tired the lower to a tree. (redneck safety) then knocked the pin out and undid the 6 bolts and pulled it out (i didnt cut the leads as they have a little tag inside that lets you get the white connector off but after lots of cursing if i did it again i might). i would surgest backing all 6 bolts for the tilt out at least 2 first as they can be a pain and if they break then the whole motor has to be removed. maybe with a socket set and insert tip you can get the last screw with out removing it
What tool did you use to get that last screw I'm going nuts
Will Bark
Don't know about Glenn but on mine I loosened the manual release valve and lowered(pushed) the tilt cylinder down all the way. Then I pulled from the top of cylinder outward and lifted the whole assembly out and carried it to my shop to take motor off and install the new one. Yours must be different, because mine only has four bolts to take out plus the tilt cylinder pin and the whole thing comes out as a unit.
sry i was saying that you might be able to use a 1/4 socket and extension (about 2") then use a screw driver tip in the 1/4 socket (tape holds it in place) i pulled the whole unit to change to a diffrent boat the one with trim and tilt came out in one piece easy as pie. the one with out the trim just the ram was a pain the bolts broke and i had to pull the whole engine off and spent 2 hours getting the transom sides off. thats why i would be willing to try the socket rather than risk the bolts but you say that you already can undo them so your started better to just carry on now
