Tilt and Trim problem
kenskat1
I have a 1990, 90 HP johnson. I replaced the trim motor about a year ago. The motor runs fine, But it moves the motor real slow. I raised the motor all the way up and put in oil to the top of the screw on the side of pump. was this the correct way to top off the oil.
D
DJ
Guest
Re: Tilt and Trim problem
OK so far. You may have to do that several times.
kenskat1
Thank You for your help.
ezeke
The fill hole should be on the back of the reservoir, not the side, facing aft.
It's similar to the one in the thumbnail.
kenskat1
You are correct SIR: It is on the back. Thanks
