I would think you have a 2 wire motor. If so, you will have relays, not solenoids. Relay box needs heavy ground and power wires to operate PTT motor via relays.. These must be clean and tight.
If a 2 wire motor, put ground on one wire and + on the other wire. Motor should spin if it is good. Reversing power and ground will cause motor to turn in opposite direction.
