tilt and trim question
rosser1
i bought a boat with a 90 hp mariner and trim works good was wondering if i need to put any oil in it, or grease in grease fitting on top of cyclender to tilt.
barryll
Re: tilt and trim question
I'm sure someone with that type of motor will answer this question but do yourself a big favor and get a manual for that motor.
Silvertip
And did you realize the title of this forum is "Props" and has nothing to do with Tilt & Trim?. But since you asked -- if the fluid level is low you need to add some. If it's not you don't. If you see a grease fitting (anywhere) -- grease it. Some grease is better than no grease.
