SanAntonioDad
- Joined
- Jun 5, 2017
- 8
Hi guys,
I'm new to the forum, but I have quickly seen that there is a lot of knowledge on here. I just picked up an old boat for a project to keep me busy. Before the wisecracks start, I know it will keep me busy (and probably broke!
). It's a 1962 MFG Seaway 19 foot. It was sitting for about 9 years uncovered. So, I cleaned it out and pressure washed it. It has a 74 Mercury 1500 on it. The previous owner states it was running when he parked it. For health reasons, he wasn't able to take it out anymore. Anyways, I know I have a big project here.
I pulled the plugs, sprayed some marvel mystery oil in the cylinders, and hooked the battery up the other day. Two things things I learned in the process: 1. It wouldn't crank. I figured out the problem is in the harness (at least that's the first problem). 2. The trim motor kicks in for both up and down. It lifts the motor just fine, however it doesn't let it back down. When you push the button to bring it down, you can hear the motor spin, but nothing happens. It is a completely different sound than when it is going up.
A question about that tilt.
I started looking at Amazon and EBay and found a lot of pump and motor combinations. The ones that are listed for my motor are crazily expensive. Is there any reason I would have to use the one designed for this motor, or can I use a different model? My thought is that it is a separate entity, and as long as it has the same plumbing (i.e. two pressure lines and two return lines) and is designed to lift that large of a motor, it should work. Is there something I'm missing here?
Anyways, I'd appreciate any help I can get.
Robert
Robert
