bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
Here is what I have found so far. The remote has the trim switch which has 3 wires which then goes under the helm and is then wired into a 5 wire cable, 2 of which I believe goes to the gauge. This cable then goes to a round 5 pin plug. This setup was originally connected to a 1988 Evinrude 70hp.
I now have a 1987 50hp with PTT. This has a 4 pole square connector with 3 12 ga. wires, red, blue and black that goes to the pump motor. Then there is a 14 ga. black wire that goes to the cylinder opposite the pump.
So after a few searches here and on the web it looks like there should be a relay or a solenoid of which I can't seem to locate one on this engine. So what am I missing and how do I connect the 2 different plugs?
