Tilt bracket stop rod...
MTboatguy
I have a 9.8 mercury tiller steer motor and I was wondering, where is a good place to get a new tilt bracket stop rod, it is the rod that goes through the transom bracket with the little flipper on it to stop it from falling out, I have been using various rods over the last couple of years, but sometimes when the motor bounces up, the rod vibrates free and heads to the bottom, so I would like to get the actually correct one with the spring and the little flipper on the other end.
Put a nut on one end.-----Drill a hole and use a hitch pin on the other end.
