Tilt Fluid capacity? 1997 Mercury (Tracker) 90hp
silver007
Single piston. Anyone point me to this? Also I see where ATF can be used, but that doesn't really narrow it down much as there's a billion types.
Grub54891
I just fill them till it is level with the fill plug. Most use a light oil, called tilt/trim fluid, also I think it's the same as some steering fluids. Atf of most types should be fine. Why is it low? Does it leak?
Chris1956
Honorary Supreme Mariner
Dextron III ATF was the original spec. I think it is Dextron VI now....
silver007
I'm just not sure how much to buy. Guess I'll just get the 8 oz bottle of power trim/tilt fluid. It doesn't leak but one trip it didn't want to trim up under power. Then two trips after it worked fine. I figured I'd flush it for maintenance.
