Tilt Motor for AQ270
74bayliner
I have an AQ270 Electrolux KS3884/290.
My old one the bolts snapped so i purchased one from craigslist for a good deal...
does anyone know how i would be able to hook this up to a battery to test to see if the motor spins?
captmello
Re: Tilt Motor for AQ270
you should be able to jump it with a 12v battery or charger. How many wires does it take?
74bayliner
its a 4 prong.. which wires would i connect to the battery there is believe... so i think its 4 wire... but per my diagram i just cant seem to see the 4th wire on the diagram... which colored wires do i connect to battery to test it?
74bayliner
i love it with this new iphone i can take pictures of everything now :)
captmello
sorry, I haven't worked with a four wire, just two and three wire...Maybe someone else knows.
Following your rebuild, good luck too you!!
74bayliner
thanks after the engine and outdrive are done, around march or so i will begin the fiberglass work.
sqbtr
Man, you should have asked before jumping on that purchase. The four wire is an outdated poor performer. Best to change to a two wire.
Google AQ280 service manual and it will have the wiring diagram for the four wire.
SteveMcD
Up=black to +, blue to -. Down=yellow/green to +, brown to -.
74bayliner
Thank you all, I will be testing it tonight when i get home, will post results
