JBtwist
- Joined
- Jul 22, 2018
- 58
When the one in the picture operates does the front of engine raise or lower? They do make some noise which is normal. Sometime the steel hydraulic lines will rust and leak . Or the rams on the side of the engine will leak. If the brushes are either stuck or worn out they can be repaired. If the brushes are stuck you just have to free them up, there may be a small ball bearing in the end of the shaft to keep it engaged in the pump. To reinstall the brush head use a 3” length of stiff wire bent into a “V” to hold the brushes in their holders, after the brush head is seated then pull out the wire, if you try to force the brush head on you will destroy the brushes.
The one down on the port side rear lifts the drive for TRAILERING & BEACHING. Never try to plane the boat off without the drive in the full down position unless you want to spend around 2-3k on repairs.
On my motor, the trim makes noise when up and down is depressed, but nothing moves. I can't find a hydraulic resivoir. I haven't stressed about it, but my trim doesn't work. Not sure if that's a have to have, or a nice to have...
