DailyDriver
- Joined
- Nov 30, 2003
- 6
1991 FourWinns 205 Sundowner, 5.8L, OMC Cobra. Tilt lowers fine. Nothing when trying to raise it, no motor running, no click, no nothing. <br /><br />I do have the manual. It says there are two solenoids, but there is only one! There are two 50 amp breakers mounted on the engine. I can't tell from looking at the schematic if these are for the tilt, or what. Looks like they are hooked up to everything from the starter circuit, ignition system, to the tilt assy. There is also a 10 amp breaker on the tilt assy. I have pushed the red buttons on all to no avail. I have pulled apart most of the connections I can find to make sure they are making good contact. I do have a voltmeter, but really don't know how to troubleshoot this problem. Could somebody give me a hint where to start? If you have info on which wires I need to focus on (colors for up/down), that would certainly make ferreting out the problem much simpler.<br /><br />Thanks
