tilt question for Clanton
lennit
Hello, i have a 1987 85hp Force that has the famous tilt bleed down when lifted, i see a lot of post for the 125 but not the 85.. can you give the the fix for this tilt,if you have it i would be greatly appreciated<br /><br />thanks a bunch<br /> :confused:
Code:
Lennit
clanton
Re: tilt question for Clanton
Will get you pn for seal tomorrow. This system should be same as 125.
lennit
it appears that pump motor has to be removed i see no way to get to the front plug and snap ring for it rest right up against transom.. thanks you so MUCH for respondind.. it is getting annoying to say the least<br /><br /> thanks again<br /><br />LENNIT
clanton
Where are you located in Florida? If you are close I will stand by and read you the instructions, with safety tips.
lennit
Originally posted by clanton:<br /> Where are you located in Florida? If you are close I will stand by and read you the instructions, with safety tips.
lennit
I LIVE IN WEST PALM BEACH FL..<br /><br />THANKS
Realgun
Will you come to Albuquerque and fix mine too? J/K<br />Will have to fix after I replace the insides of the boat. Mine is the 85 hp model that is leaking down.
