Tilt/Trim clicking
vicda98
My motor will raise and lower, OMC 92' 115 V115SLEND, but when it does there will be a clicking sound. I just put some quicksilver trim/tilt fluid in the resivoir thinking it was low, but the clicking sound is still there. Any advice would be greatly appreciated.
rickdb1boat
Re: Tilt/Trim clicking
May need to grease the tilt tube. Could be binding up some. Does it sound electrical or mechanical?
solidwaste
If it is electrical you probably just have a bad syliniod..
vicda98
Rick,<br /><br /> Sounds mechanical, clicking not coming from the tilt motor, what kind of grease is good for this? And is there a fitting wehere you put the grease in?
nektwister
Its probably the solenoid i have a johnson 115 1978 and mine was the same problem try the solenoid it worked for me.
vicda98
I'll check both the solenoid and the tilt tube and get back with yall with my results. I've got a Seloc manual for my engine, this should tell where the solenoid is mounted?
