Tilt/Trim Experts Needed
dodgeman67
Finally got the seized end cap off of the trim cylinder from my 1976 Evinrude 115hp model #115693D. Had to drill and tap two pin holes with a 1/4 20, screw down a homemade spanner good and tight, use a cheater pipe all after much heating with smoke wrench. Was excited that it finally gave, then I discover what looks like another plug with two pin holes under the end cap that appears to be seized in there pretty good. Form schematics I gather this is the "piston bearing"part number #122503. Is this part threaded and if not how do you suggest I get it out of the cylinder. I am trying to be patience as to not tear up anything up but don't know how I can get anything into these pin holes. Thanks
