Re: Tilt & trim for 86 110 jonny
You will also want to get the engine tilted all the way up to add the fluid. If you can't raise it, look through the starboard transom bracket for a slotted head.....you'll see it through one of the holes in the bracket. With a large screwdriver, turn the slotted head counter clockwise at least two full turns. This is the manual release and wil allow you to raise the engine by hand.
Once the engine is up, prop it up if you have to and close the manual release. Now add fluid and see if the unit will start working. If it does, repeat the process.
If you get it to go up and down, cycle the engine all the way up and down 3 to 4 times and leave it up. Check the level in the reservoir and add as needed and repeat the cycles. When the fluid level stays even with the bottom of the fill hole, the system is full.
