Re: tilt & trim For a 85ETLR76G
Ill assume you have 3 wires coming from your remote control, a green/white, blue/white and red white?
3 wires coming from the trim motor....blue, green and black?
The red/white wire coming from the remote will go through an inline fuse, to the power post on the solenoid, then to the positive post of your battery.
The black wire coming from the trim motor will go through the ground on the solenoid, to the ground post on the battery. There may be a brown/black that ties in as well, coming from a trim gauge if you have it.
Green wire coming from trim motor ties into green/white from remote control.
Blue wire coming from trim motor connects to small post on solenoid. Blue/white wire coming from the remote connects to small post adjacent to the previous one.
