Tilt Trim for my 1979 115
bonito1
Hi all. I found the following description for an OMN tilt/trim on EBAy. Anyone know if it will fit my motor.
"This is a slightly used if used at all johnson evinrude 397798 cylinder
assembly ay tilt boat trim pump.it is in good clean and working condition.
i don't no much about this type of item .based on what ive found its
it was made in 1993 and is a crp but i cannot confirm this. what you see in
the pictures is what you get. no other parts included. the following is
what ive found on the unit..it weight is 22 pounds.see pics for condition.
1. 397798 m
2. 390608 s
3. 9f09 6 / 1 2 3 a b c / m / e3 / 333010 mto on casting"
willamettejeff
Re: Tilt Trim for my 1979 115
Post a link to the auction so we can see the picture of it. Sound like the right unit, but without a picture can't tell you for sure. Manufactured prior to 1996 is a good sign as they changed over to a different unit (Fast Track) in that year. Year of your motor is good, basically 1978 - 1995. Added T&T to my 1978 70hp Johnson and would never go back.
BTW, you are going to need a lot more than just the hydraulic unit to make it all work.
