tilt / trim fuse and switch
Walker2
I have a mid 70s chrysler 115 outboard. There's just green wire, blue wire, hot and ground. I think I should put in-line fuse at hot. If so what, amperage?
2nd question: Also needs new dash switch. what should the switch be rated at for amperage again?
Thanks for any help on this
Yes put a 20 amp fuse on the hot
You should be using relays so switch rating can be less then 20 amps, but heavier is always better in these cases
Walker2
Thank you AllDodge for the help. I don't yet know what a relay is but your diagram helps. I will get it done!
Walker2
One more question AllDodge, what relays should I buy?
Walker2
Grateful once again AllDodge! You're making this a lot easier !! I'll let you know how it works out.
89retta
If I recall right on my old 120 HP Chrysler there was no relays in the tilt/trim system.
