Re: Tilt/Trim Kit for small Mariner outboard
luv2boat.
First. thank you for your service.
Not sure where you are going with this thread.
Is it not possible to put the motor in revervse to get rid of the weeds and Go foward.???
I do this all the time duckhunting.
More details would help.??
It was an honor to serve and thank you for your comment.
I do the reverse the motor thing all the time too. But some of the weeds around here won't cut all the way off so I have to raise it all the way up and cut stuff off. I also raise it up onto the shallow drive to keep crap out of the prop, but all that takes lifting the motor around which is becoming too difficult. I could go with a simple lever device on tgop of the motor for a while, but something I can make cheap and electric or electric-hydraulic, that would be best. Money is an issue here, but mechanical skills are not. I look at most projects like this; If I can take apart a Sikorsky Pave Hawk and put it back together, I can handle a lot of things.
I've been googling different types of linear actuators, electric motors, rams, etc. My last thought was a starter motor on a bracket as a screw drive type of thing.
