Re: tilt & trim oil
Ha! I was just about to post the same question (well, not regarding the power steering). A few related follow up questions re: the trim/tilt:
1. My Seloc manual says to use one of the following for the trim/tilt: MS, SD, SE20W, 5W-30, "or equivalent". Is the 30 weight engine oil I use in my Merc 140 considered an "equivalent"? I already have it handy!
2. I have no idea what type of oil is in the trim/tilt reservoir right now. If the answer to the above question is "yes" and I elect to add the 30w oil, will I cause problems if the oil already in there is different?
3. The manual also says "anytime the trim/tilt system is serviced for any reason, including the opening of a hose or fitting,.....the system must be bled" I assume you don't have to do this if all you do is top off the reservoir?
Thanks guys!
