Tilt Trim Power Wire to trim motor ? 92 Force 70 HP
crappie14
I have a tilt/trim unit that I have acquired on a parts motor that I was looking at installing on a 91 Force 70 Hp without trim. I know the trim unit worked a couple of years back when put in storage. The rubber coating on the power wire going inside (top connection on trim motor) has all but broken down and peeled off. Copper wire is showing in many spots. Does anyone know what type connection there is under the removable water tight nut where it enters the trim motor? My question is "Is this the type repair that can be done by someone with some skills or does it have to go to a electric motor rebuilder to swap out the power wire?".
Thanks in advance.
