Tilt/Trim Problem
Truckie15
Seem to have a problem with my tilt/trim. It may be as simple as low fluid or it could be something else. The motor seems to work just fine, however when I press the tilt/trim button the tilt motor goes but will not raise the motor. Should I be able to tilt the motor up by hand, because I can and I thought when full with fluid I wouldn't be able to. There is no fluid leaking anywhere. What is the process to fill the tilt/trim unit? This is a 1986 40 HP Yamaha made Mariner.
Thanks!
