Tilt/Trim pump fluid
Walkersteelhead
I did a search but I couldn't find any info on fluid for my trim/tilt pump. It is a type 1 outdrive. What fluid do I use.
cuzner
Re: Tilt/Trim pump fluid
atf will do the job<br /><br /> Jim
rodbolt
I think the type ones used 10w-30. should be a tag on the pump unit.
beezee28
Master Chief Petty Officer
I used the 10w-30 oil. Check your owner manual for the right kind of oil.
vipzach
My owners manuel says to use 10w-30, that is what I use. I was told if I got all the 10w-30 out I could also use atf. As said above, check your manuel though.
Either ATF Or Engine Oil will work.........<br /><br />Actually, Any Oil in the thinner weights will work, Just Fine...........
