Tilt/trim question.....
js361
Does anyone know if the fluid used for this is the same as automotive power streeing fluid?
Barnacle_Bill
Re: Tilt/trim question.....
It depends on the motor. Mine uses 30w oil. Others use an ATF type. and I'm sure there are other types.
Texasmark
Dip some out of the sump. You can tell the difference by looking at it. I think the older trims used the oil and newer use ATF or QS PTT fluid. Better operation at cold temps.
Mark
