Tilt trim solenoids
AFGguy
I recently replaced the two sole kids on my 1987 Mariner 35. Now i get nothing when I try to raise or lower. Thinking it could be the motor, I connected straight to the battery and it worked fine. Now. I don't even get a click. Just nothing. Could I have the wiring wrong? Here are the pics to the TT solenoids and the starter solenoid. Any help would be greatly appreciated.
Check for a blown fuse, otherwise need a voltmeter to trace voltages
AFGguy
I get voltage to the starter solenoid, but nothing g form the tilt trim solenoids
With fuses good than guess is you left a wire off
The power comes from the battery to a the trim solenoids and to trim switch. The trim switch applies power to the solenoid when needed
AFGguy
I'll have a look
